Apps ImageButton Force Close?
I want to write an app containing an ImageButton. In order to do this, I've googled a few tutorials and browsed the Android developer site.
It seems simple enough, but everytime I've tried to get one working, I get an "application <X> has stopped unexpectedly. Please Try Again" message.
Any ideas what could be going on?
I have a very simple app here with two trivial sized images - 17k. The app simply is supposed to change the image when clicked.
Is there an issue with ImageButton in any version of the SDK?
MyImageButton.java
Code:
package com.perfectreign.imagebuttonexample;
import android.app.Activity;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Toast;
import android.widget.ImageButton;
public class MyImageButton extends Activity {
    /** Called when the activity is first created. */
	ImageButton imageButton;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        addListenerOnButton();
    public void addListenerOnButton() {
    	imageButton = (ImageButton) findViewById(R.id.imageButton1);
    	imageButton.setOnClickListener(new OnClickListener() {
    		@Override
    		public void onClick(View arg0) {
    			Toast.makeText(MyImageButton.this, "Image Button is Clicked.", Toast.LENGTH_SHORT).show();
main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
<ImageButton
	android:id="@+id/imageButton1"
	android:layout_width="wrap_content"
	android:layout_height="wrap_content"
	android:src="@drawable/android_button" />
</LinearLayout>
