Help Images appear distorted?!
zidoff
Dear All
I'm using Samsung Galaxy Ace (GT-S5830); images appears distorted or scrambled when browsing in Gallery!!!
is it a hardware of sowtware fault?
if hardware I should return it back and get a new one
and
it's sofware anybody have the solution?
Thanks in advacne.
Images might appear blurred for one or two seconds as soon as you open the gallery.But they clear out in a fraction of second as it takes some time load.
Thanks Muk343 for your reply, seems the problem is from the SD Card I replace it with another one and I'm in a testing process right now.
