Help Images not showing within apps
Hi,
I have just started to notice images are not showing inside apps on my device. For instance, I play clash of lords 2 and in the reward section you can swap points for different items, except now you cant see what items are available because all images are greeted out with a little green icon in the corner. I dont know if I have blocked access accidentally or what. It is also happening on my wegamers account where no images show - not even my profile picture. Its driving me mad lol. I have looked through settings and cant find anything... scoured internet and have turned up nothing... can anyone on here help plz???
It is a samsung note 10 plus and the problem has only just started last night.
And yes I have 64Gb sd card. It is internal but didnt know there was a setting to set it as internal??? Can you tell me more?
Ok stop first off the note 10+ actually does not have an option to use the sd card as internal. On some devices, especially those with limited space, the manufacturer will put in an option to use the sd card as the phone's storage. Because sd cards can get corrupted easily, it can create issues such as yours.
Have you tried uninstalling and reinstalling them?
