I'm stuck in the following problem and I don't know what to do:
Main Activity:
ImageViewActivity:
In the manifest I wrote the permission:
I tested this on my phone and on a tablet and it works perfectly. Using this:
Or this:
Or even the hardcoded path.
But on the tablet that we are releasing it does not show the image on the imageview.
This path is the one that appears if I see the properties of the file on a file explorer:
Even if I hardcoded it, it doesn't work.
And this is what the file explorer says at the top:
The tablet is running Android 5.1.1.
What am I missing?
Main Activity:
Code:
package com.example.rwallpapers;
import android.app.Activity;
import android.content.Intent;
import android.net.Uri;
import android.os.Bundle;
import android.os.Environment;
import android.view.View;
import android.widget.ImageView;
public class MainActivity extends Activity {
ImageView mImageView;
String path1 = "/mnt/internal_sd/Pictures/RP/1.png";
String path2 = "/mnt/internal_sd/Pictures/RP/2.png";
String path3 = "/mnt/internal_sd/Pictures/RP/3.png";
String path4 = "/mnt/internal_sd/Pictures/RP/4.png";
String path5 = "/mnt/internal_sd/Pictures/RP/5.png";
@Override
setContentView(R.layout.activity_main);
public void launchImageView(View v) {
switch (v.getId()) {
case R.id.imageButton1:
Intent i = new Intent(this, ImageViewActivity.class);
//i.setData(Uri.parse(path1));
i.setData(Uri.parse(Environment.getExternalStorageDirectory().getAbsolutePath()+"/Pictures/RP/1.png"));
startActivity(i);
break;
case R.id.imageButton2:
//i.setData(Uri.parse(path2));
i.setData(Uri.parse(Environment.getExternalStorageDirectory()+"/Pictures/RP/2.png"));
startActivity(i);
break;
case R.id.imageButton3:
i.setData(Uri.parse(path3));
//i.setData(Uri.parse(Environment.getExternalStorageDirectory()+"/Pictures/RP/3.png"));
startActivity(i);
break;
case R.id.imageButton4:
i.setData(Uri.parse(path4));
//i.setData(Uri.parse(Environment.getExternalStorageDirectory()+"/Pictures/RP/4.png"));
startActivity(i);
break;
case R.id.imageButton5:
i.setData(Uri.parse(path5));
//i.setData(Uri.parse(Environment.getExternalStorageDirectory()+"/Pictures/RP/5.png"));
startActivity(i);
break;
Code:
public class ImageViewActivity extends MainActivity {
ImageView im;
@Override
setContentView(R.layout.activity_imageview);
im = (ImageView) findViewById(R.id.image_content);
im.setImageURI(getIntent().getData());
//Toast.makeText(getApplicationContext(),"hello", Toast.LENGTH_LONG).show();
Code:
<uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE" />
Code:
Code:
Code:
Code:
NAND FLASH/Pictures/RP
What am I missing?
