Imei problem
talentxulu5
Hi guys I bought a galaxy s5 from some guy. ... so apparently I tested its water resistant but the back cover wasn't sealed properly.  Water got in ..but after two days it was fine but it showing no singnal now. .. ime number showing null null n baseband unknown
Here's another problem
Download the app over WiFi and post a screenshot of what is listed under Firmware and CSC codes. With this information you should be able to find the correct firmware at Sammobile.
You could also try Kies3. It will select and flash the correct firmware based on your model number and SN.
Follow the guide here.
http://www.samsung.com/ca/support/skp/faq/1072789
