b_randon14
Android Expert
I was going to ask some of you experienced dev's out there where would be a good starting point to look for the sms split fix that was implemented into the CM code that allows the CM& mms.apk to split up sms's over 160 characters itself. The stock Triumph cannot do this, because I increased the sms to mms threshold and it would not convert it to a mms after one sms but it would fail to send it because it wouldn't split it up itself.
Is the fix in the mms.apk or in the framework or somewhere else. Also if anyone who is pretty well versed in AOSP/CM source code point me in the right direction to look I would like to port this over to the stock ROM mms.apk!!
Thanks to all who help out!!
