chadyboy81
1 i wore mechanic gloves rubber coated
2 i taped the crap out of the papper clip i was using
3 be ready to do wire trick if your nervous and hands are shaking like mine get the papperclip aligned with the outer hole in it barely but not touching the metal plate yet not til it says "do wire trick"
4 it says to do wire trick after backups and it makes room for beer on sd card after that be ready then double tapp it as many times as your able to then you should be good , if not you may have to take your battery out and try again
5 i was stuck in joupunut bear boot until i finished and ran these commands you can use git bash or when your in the {controlbear folder} hold shift + right click. open command window ,
*then run "controlbear.exe -r" that resets phone to normal the "controlbear.exe -f" (that gets you out of the joupunutbear boot )
*again it may take a couple times or 10 you know it works when the bar on the right starts off red then green and you reboot
i hope this is helpful and anyproblems you can go to Unlimited i.o. .com
