Help Impossible is not a solution
outtaluck
Ok, I've been at this for two days now. I'm trying to get an S4 to display on a computer screen so it can still be used until the owner can afford a repair.
The screen isn't cracked, but the LCD and Digitizer are completely broken. The phone still functions when connected via USB.
- side note, my phone is currently in the same condition but before it went down I had it rooted and put into debugging mode. I was able to accomplish this feat without an issue, from my phone.
Okay, so the phone I'm currently trying to get this to work on:
1. Isn't rooted
2. Screen is black and no touch response
3. Not in developer mode, not set for debugging
4. Computer can recognize phone via USB
5. Able to still install apps from the goggle play store via the website
Goal: get it to be able to mirror/display on a computer
I've seen posts on the internet stating everything from impossible to no it's possible but we won't give you the details.
These things are basically handheld computers, even without it being "rooted" i should be able to access it in some way from a computer to put it in debugging mode even if i have to program it in myself. Which is why "impossible" is something I cannot swallow.
Any tips, advice or a point in the right direction here would be appreciated. Thank you.
-currently im trying out this Mobile Go program even with the phone not in debugging.
-I feel like there has to be a way to force the phone into debug mode even if you cannot physically use the touch screen or see anything.
There isn't. To be able to communicate with the device via ADB, USB debugging needs to be active. It's a Catch 22.
Something like this might help: http://www.amazon.co.uk/dp/B00GOXYE...m=A3P5ROKL5A1OLE&pf_rd_r=1J7MPW56C8TS2HN875B2
The HDMI port allows you to plug it in to a monitor or something and the USB socket should allow you to use a mouse as an input device.
Try Samsung SideSync. It can display the screen on a PC and control with mouse and keyboard. I can't remember if it can be made to work without activating debugging, I'm just hoping it can for your sake coz it's proprietary Samsung software anyway.
