Help in-call volume too low
ajaynatu83
Member
hi folks,
been using galaxy note for almost 2 weeks now....
when m on a call the volume is too low. Specially when m outside on the road or in the traffic then its hardly audible :(
Initially i thought m not holding the phone properly close to the ear. However that wasnt the problem. I guess the default max in-call volume is low:(
-Is there anyone who is facing the same problem and what did u do to solve the
problem?
-Is there any way to increase the in-call volume (other than using any app)?
-If no, then which app can help me increase the volume?
request suggestions .....
This is what you need to do during a call turn the volume up. My in-call volume is at half and my ring volume is at quarter.
Thx for the suggestion..
during the call i did turn the volume up to max. Still it wasnt satisfactory specially when m out on the road n traffic around. There isnt any problem when m indoors.
Is it that the background noise cancellation is reducing the other persons voice down too?!!!
I saw a post in galaxy s2 forums where by typing few numbers v get some menu n then one can twick around with the volumes. It also said it doesnt work for note. So any idea if der is any such thing for note as well?
I DO NOT WANT TO ROOT THE PHONE N DO IT.
Any way to increase it folks???
I found When I got my note, I was not placing the ear speaker in optimum position when it was held to my head to hear it. Had to rotate the phone to find the sweet spot.
I also like Volume Ace to control all of my volume levels.
Hope that helps.
