zuben el genub
Extreme Android User
Which is more the cause - pressure on the screen or a stuck button?
I'm pretty sure the cause was physical as I heard the phone buzz and vibrate before I put it in the holster. When I took it out later, it was stuck in reboot.
Battery pull fixed it.
I could have also hit the power button and volume putting it back.
We are having work done on house - so I'm a bit distracted.
Depending on the cause - a new holster might be in order.
