Hey guys, i've recently built the Libusb library using ndk-build to produce the .so. Now i need to be able the call functions for my app. Im trying to make a .c file that will call Libusb, and use the jni/ndk to link this to eclipse. For example:
The problem is, that it will compile fine with ndk-build - giving me a libs folder with libusb.so and libmy_lib.so, but when i run it from eclipse, LogCat gives me the error - UnsatisfiedLinkError : Library my_lib not found.
Im sorry for the awful explanation, but if you understood and could help, that would be great! Thanks, T.
Code:
JNIEXPORT jint JNICALL Java_com_usb_NativeLib_init
(JNIEnv *env , jobject obj){
int i = libusb_init(NULL);
return i;
