Incoming call volume automatically shuts after phone call
pmhtro
Hi everyone,
I have a problem with my phone after an accidental movement that i am trying to consider what it was.
So every time i change the volume control for incoming call to max or near it, after the first call that i can hear the phone ringing, when even i or the other side hangs-up the volume automatically goes to min (muted) as the screen dims before it goes off. The next call is muted and i miss every call from that point because i cannot hear them. If i change the volume again to max or near it the process goes the same way.
I wonder if there is a trick or quick solution to the problem or if it is a bug of software. I'm using the phone 5 months now with no problems. I tried the advise that support team addressed, that is perform a backup and factory reseting the device. in the beginning seem to work ok but after a while the problem raised again.
Hopping in an answer by someone who knows well the device...
I am having a similar problem. After every call, no matter who hangs up, a volume meter pops up on the screen and mutes all my media volumes or ring volume, etc.
After I get an incoming call and hang up, the volume goes down to 0 and the volume control is shown on screen as if I pressed the volume buttons. After that every time I make or receive a call, the volume controls are shown again.
The volume goes to 0 when the phone begins ringing, then goes back to its normal level when I hang up. Sometimes it does not go back to its normal level though. I tried clearing the data of the dialer app, which did not help.
Edit:
The problem gets fixed when I restart the phone or kill all apps and background processes/services. However, it comes back after some time. I currently suspect Google Navigation. If I get a call while navigating (not just maps) the problem comes back. I tried to look at the LogCat but couldn't recognise down the cause.
