Help Increase mt4g hspa connectivity/speed
pleaseno
I just replaced my old screen mt4g with a newer one and it has much slower hspa speeds then my original. Is there anything I can do to help this?
change your server you test from and maybe you'll see more favorable results, i am in michigan and the default speed test was in deleware or something crazy and the ping resulted in seeing very slow speeds
your situation might be similar
to change server, if using the speedtest app
-click on "settings" on top of screen
-then "change server"
I wish it was that easy. Already did that..... It thinks I'm in north carolina...my overall hspa service is horrible... Looks like I might be getting a third phone
