Root Incredible 2 Rooted with Multiple Issues
akaSTRECH
I bought my phone a few days ago and I thought booted meant i could get exceptional signal...thing is I have only been able to get two bars since I have had it. Options???
My photos after I take them are upside down..........what to do??????????
I have downloaded gtunes music v6 and I edit parts of the songs into ringtones. Unfortunately, when i set them as a ringtone it is silent. What can I do to make them be heard or what app can i download with a ringtone editor that will actually play the ringtone?
You are saying "booted". Do you really mean Rooted? If you are rooted, did you install a custom ROM or are you still using the stock ROM?
akaSTRECH
I merged your threads into one thread and post as you have multiple issues that you will receive better help with in one thread than in 3 separate threads.
First, Did you make a nandroid backup immediately after rooting?
Second, did you flash a custom ROM? If so, what ROM?
Kratos
I rooted my Droid Incredible 2 a while back by downgraded the GB 2.3.4 to 2.3.3 and am really happy with it except for one following issue:
- every time a SMS message is received, it reroute my bluetooth call to the handset.
Is there a fix for this? I read that I need to upgrade to GB 2.3.4 - how can I do this with a rooted phone? I checked for new software - Settings -> Software update -> Check new but nothing came back.
Thanks
