Incredible Auto Air Vent Mount
Valkryn
Just wondering if anyone has came across a good air vent mount for their Incredible. I'm looking for a good way to mount the phone while driving but don't want to mount it to the windshield.
I drive a 2010 Tundra and it seems the best place to mount it for a good view of gps use would be the air vent. Can anyone recommend a good one?
I use a generic one that works on the air vent. I bought it for my Moto Droid and it worked flawlessly and it does work good with the Incredible but it's a little trickier to mount & charge because of the location of the micro-USB port. You can swivel it to mount vertically or horizontally though.
Link
The SM310 looks to be the best deal because it has both windshield and air vent mounting options for the same price as a stand alone air vent mount.
I can vouch for the ProClip, top notch. I emailed them about a mount for the DInc, they said it was on it's way, no ETA.
I went to staples about 2 days ago and found a really nice mount where the side arms slide up and down and expand depending on the size of the device. It will also swivel and tilt to landscape and portrait modes. It was $19.99 and was well worth it.
