Accessories Incredible + TV OUT Cable + Jabra Clipper + Pandora = AMAZING!!!
patchnauty
So I recently purchased this:
This:
and of course this:
So I listen to Pandora in my car and connect this Jabra clipper minus headphones and have a wireless track skip and pause. Such a simple process too. Connect tvout cable, Once connected turn on Clipper.
I clip it on my seatbelt and have complete wireless goodness.
TV out cable enables you to use a TV as a monitor to see what is on the cellphone screen better and sometimes in cars to make the GPS easier to read. I have a 9 inch Sylvania TV that is very clear unless I use the video out cable from my Dinc. Then the quality is unusable. I am going to show the Verizon folks what quality video I am getting because something is wrong. The cable hooked up to my HDTV is equally bad. They told me two weeks ago the cable couldn't be bad if I had any picture at all because it is analog.
Finally got to take some pics of my setup on a 2006 tacoma xrunner. Used my old storm 2, so pics may not be that clear.
TV Out cable works great with Google Navigation along with Slacker running in the background. Slacker will mute if there are GPS instructions being read out and will continue playing music once the GPS app has finished talking... Tried a couple of mount positions, but this one works best for me. I've tried the cup holder mount and windshield, but like it on the side better...
Anyways here are some pics..
So what's goin' on here... you're using the TV-out cable into the deck's AUX input jacks, and get video and audio from the phone to the screen? I might have to try this on my Kenwood stereo .....
My headunit has an input for AV1 & AV2. I guess extra inputs for some video source and a backup cam... If you have an aux in with video then you can hook it up there.
Went to Verizon today and showed him the lousy video out quality and he agreed. He spent 30 minutes trying to see what was wrong but didn't have a replacement video out cable to test my system. It is totally unusable so he said call tech support. I already know where that will go without another cable to compare with.
