hbryder
Indexservice is using majority of battery (fast!) What is it?? Wondering if it has anything to do with the play store...
Different question, I used two google accounts (mine and my daughters) on my s3 and never had a problem. Today while setting up I added both accounts, started downloading my apps then all of the sudden started gettting errors (wouldn't download, error connecting to server) Then went to my pc, same issues, on a whim I logged into my second account (only used for calendar, and it's all that is checked in the google services menu) sure enough it worked and downloaded the app (from the pc, not the phone) Removed second user, restarted and now it's fine. Unfortunately I would really like to continue using that second acct..any ideas??
