A
Android Question
Guest
I have a Viber factoty installed version and want it off my phone. How/Can I get rid of it???
My phone went into an infinite loop when I disabled Viber and I thought it was bricked for good.
Background: ALCATEL Smart Gold TCT One Touch 4033e (aka One Touch)
I apologize for being verbose, but I want to include as much detail as possible for anyone having similar problems and also hope for critique to ascertain exactly which factors helped in the recovery. And finally, how to get of this ******* thing off my phone.
I have Viber factory version on my phone. I did update the app via Google but decided it just was not an app I wanted or needed. So I decided to get rid of it. I uninstalled the update. But I found that there was no uninstall of the factory version and it still showed as running. So I decided to disable it. I had no ill effects at that time. But the next morning when I unlocked the screen the phone seemed to be stuck and I rebooted it. That is when the trouble started. I the first time I eas able to enter my lock code but then immediately got the message
