nitramus
I try to get as much info as I can before doing anything and everything seems to be scattered everywhere in different places and very hard to find. There should be a sticky on everything about radio/firmware.
my HTC desire gsm has baseband 32.49.00.32U_5.11.05.27 and I am wondering if I should update. The only real problem I am having is the signal strength. I am trying to find the changlog for the different versions to know if it is really worth it to change but just can not find anything at all. If it even exists.
I think I understand the 32.49.00.32U is the baseband and the 5.11.05.27 is the radio/firmware.
what is the relation between the different baseband versions (or does it change anything) and the the different radio versions.
[RADIO] HTC Desire Stock Radios [LATEST 5.17.05.23] [29/05/11] - xda-developers
This thread as over 200 pages and I just cant take hours after hours to find bits and pieces.
Also found this page on one way on how to update the radio
[UTILITY] Android Flasher 2.2.0.5! (12/12/11) - xda-developers
HTC Desire (GSM): FAQ - CyanogenMod Wiki
Revolutionary
rooted with S-OFF
radio 5.11.05.27
Hboot 6.93.1002 (still stock I believe)
CyanogenMod 7.2.0.1 stable
So.
Should I update and what is the best way to do it.
Revolutionary
rooted with S-OFF
radio 5.11.05.27
So.
