info on sim card ?
scuba626
Hi,
I enjoy reading the forums. I have an incredible 2 i was wondering if anyone out there knows if there is anything stored on the dim card?
Hi,
I think that you are referring to the sd card on the device. Pics, music, and videos are stored on the sd card. Here is an application that will let you see, move, and edit files on the sd card. http://cjru.qr.ai
Also, here is a link to your device's area of support. HTC Droid Incredible 2 - Android Forums. ☜ Here is where you can find tips and info on your device.
I hope the info on here will serve you well. <(@ ̄︶ ̄@)>
Thanks, for the info but my DI 2 came with a sim card. I was just wondering if anything like pics,messages or phone numbers go to it. I know on other phones that do not have a sd card thingd get stored to the sim card.
I'm not sure...I've never had a phone that has a sim card. Aren't those use to connect your device to a specific carrier....?? The folks over at your device's support forum will be best to give you answers on this.
