Hi everybody, I guess most people will know that there have been three different wifi modules that have been fitted in Flytouch 3's over it's lifespan, I know the chipset in the wifi module in mine, it is the Ralink RL2070, it was I believe the first type to be used. There have since been two others, if you use Tims 6a firmware you might have had to use one of the gscripts to get your wifi working, if you did could you please find me some info?...
run a terminal emulator (connectBot, android terminal emulator, etc) and type the following -
su [enter]
lsusb
if that comes back with a 'not found' error try
busybox lsusb
you should get something like this
I'm interested in the four numbers after the 148f: and which script you had to use 0803a or 0803b.
I'm trying to find out the chipset numbers of the wifi modules used
Thanks
su [enter]
lsusb
busybox lsusb
Thanks
