First and foremost, all of this information is taken from other sources, it's just the recipe for putting the pieces together the right way. Hroark, shabbypenguin, necrotoxin and many others are the ones who did all the work.
I don't know what steps are necessary and aren't, so I will just post exactly what I did.
1) Install CWM & Cyanogen mod from http://androidforums.com/galaxy-pre...-1-0-prevail-unofficial-beta-v2d-11-06-a.html
2) Install latest hotfix (Beta 2D Hot Fix B at the time of writing)
3) Install google apps (probably not a necessary step but it's what I did)
4) Change application settings to allow installation of programs from outside sources
5) Install Wireless Tether BETA 6 wifi_tether_v3_1-beta6.apk from the website Downloads - android-wifi-tether - Wireless Tether for Root Users - Google Project Hosting (version here is crucial... beta 6 is the latest version as of writing)
6) Follow this guide >> http://androidforums.com/galaxy-pre...2451-wireless-tether-infrastructure-mode.html
7) Check the box "Enable Wifi-encryption" and optionally change channel, ssid, and passphrase options (I am not using auto-channel, haven't had a chance to test if it works)
It's working!
A few notes, you guys may be wondering why I'm writing this if it's "already been done". Using shabbymod or default rom, tethering only seems to work without encryption enabled and is very finicky, you have to reboot the phone each time you want to start it again etc. Now, you don't have to reboot the phone and the encryption works flawlessly.
Final note, this may have been due to an update to wireless tether as well, but I believe beta 6 was the version I was using in my stock-rooted phone before.
Please let me know your feedback, if you got it to work. Maybe those with stock rom can check if it's working there as well (requires root access).
It's working!
