Input Jack?
suntower
Hi,
Just got an Xperia X10 and see there are many 'guitar tuner apps'. My friends with iPhones have little jacks/adapters they can use to directly plug their guitars into their phones to tune the guitar.
Is there a similar type of jack for the XPeria? Using the internal mic to try to tune is pretty hopeless.
Thanks,
---JC
Hi,
Thanks,
---JC
The jack works for my handsfree cable, incorporating a mic, so imagine something similar might work for your needs.
That's what I figured. I just need a jack that makes contact with the 'mic' portion. When I tried a standard 1/4" to mini-plug adapter it seems to have made contact with the 'speaker' portion and did not work.
Anyone?
---JC
