I have a couple of textswitcher's that are very similar so I wanted to reuse them (the same with a TextField, but I gonna use the textswitcher as example). The views are being used in a RelativeLayout.
The textswitcher is defined in a separate xml file:
and then I would include it as:
If needed the whole mainactivity:
A tutorial said that you can override every android:layout_* attribute in the include tag. So I want to reuse the textswitcher a couple of times, and as such the id and the android:layout_toRightOf will change so I override it.
Now the weird thing is that it doesn't override the android:layout_toRightOf part. It does however work with the id. And when I for example do the same but with the following textswitcher:
Than it still doesn't override but it will lay the component out accordingly but always to the hoursTextSwitcher instead of the one I defined in my input tag.
So is it normal that the android:layout_toRightOf doesn't get overriden? And if so is there another way to reuse this component?
Code:
<TextSwitcher xmlns:android="no_url_allowed"
android:layout_width="wrap_content"
android:layout_height="wrap_content" >
</TextSwitcher>
Code:
<include android:id="@+id/test" android:layout_toRightOf="@id/hoursMinutesSeparatorTextField" layout="@layout/clock_visual"/>
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="url_not_allowed"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:padding="10dp">
<TextSwitcher
android:id="@+id/hoursTextSwitcher"
android:layout_alignParentLeft="true"
android:layout_alignParentTop="true">
</TextSwitcher>
<TextView
android:id="@+id/hoursMinutesSeparatorTextField"
android:text=":"
android:layout_toRightOf="@id/hoursTextSwitcher"
android:textSize="36dp" >
</TextView>
[COLOR="Red"]<include android:id="@+id/test" android:layout_toRightOf="@id/hoursMinutesSeparatorTextField" layout="@layout/clock_visual"/>[/COLOR]
</RelativeLayout>
Code:
android:layout_toRightOf="@id/hoursMinutesSeparatorTextField" >
</TextSwitcher>
