insane red light
  • Thread starter Thread starter alen davide
  • Start date Start date
A
alen davide
Guest
my wild fire s shows charging sing even it is not conected to the charger
Hi
My wife's wildfire S did this once. It was dirt and a little moisture in the USB port on the side of the phone causing it. I blew it out with a dry compressed air can (the type meant for computer cleaning) and its been OK since.
If this does not help suggest that you register and post the question again to the HTC wildfire S forum so that someone there can help ( you cannot respond to this reply)
(Just noticed that you have already registered)
Roger
