I InGearX Android Enthusiast Jun 25, 2014 #1 hi I am changing my device how can I port all applications? is there an easy way to install ALL the backed up .apk with one click? (and any good soft to backup without root?) thank you...
B breadnatty08 pain rustique Jun 25, 2014 #2 Your apps should be backed up/sync'd with Google so once you put in your Google account they'll automatically download. However, data from those apps won't be saved. To back them up, I'd recommend an app like Helium: https://play.google.com/store/apps/details?id=com.koushikdutta.backup&hl=en
I InGearX Android Enthusiast Jul 13, 2014 #3 breadnatty08 said: Your apps should be backed up/sync'd with Google so once you put in your Google account they'll automatically download. However, data from those apps won't be saved. To back them up, I'd recommend an app like Helium: https://play.google.com/store/apps/details?id=com.koushikdutta.backup&hl=en Click to expand... Mate please advise how to use this Now I got a new Android And want all the apps I go on Play store .. how can this be automatically done? Thank you so mucj
