Install android 4.1 firmware on chinese tablet {need help}
Hi AF
i have a chinede android 4.0.3 tablet 7"
there is no brand on the tablet cover or any ware else !
in the settings the model is : SY-V7
the tablet is force closing apps and auto rebooting
it have a lot of problems i tried to factory reset but still the same
i tried to swap user info "from the recovery mode" but still the same
i want to install a fresh 4.0.3 firmware or install 4.1
can any 1 help me with this it will be soooooo appreciated
btw there is no choice in the setting to update !!
Hello and ni hao alexander095 welcome to Android Forums. :)
Unfortunately there's absolutely no information at all on a "SY-V7"...which basically means if you want updated software, forget it. Your best bet would be to RMA it as faulty for a refund, if that's possible.
The only branding you'll often find is "FCC Approved. Made in China" :rolleyes:
You might want to read our forum sticky about these things...
http://androidforums.com/android-lounge/631594-off-brand-phones-tablets-worth-low-cost.html
...and I suggest that you buy a Google Nexus tablet instead. It will cost you more $$$, but it's worth it.
