im trying to put the viper rom but it seems to conplicated to install and i cannot find where to download the new version of the rom. can anyone help me install it and show me were to downlooad all the files?
Assuming you are rooted etc follow instructions found in http://forum.xda-developers.com/showthread.php?t=2105863 to install. The downloads are in post 5 or 6, download and install the full 2.1.0 rom, then after running it for a while download the ota update 2.2.0-2.1.0 and flash that.
wipe first in recovery (I usually do wipe system, factory reset, wipe cache 2 or 3 times each) then when you install the ROM choose 'Install without wiping' in Aroma (the installer program) also choose 'no custom kernel'. If you aren't S-Off you will need to flash the boot.img file too
