Here is the installation guide from my original thread. You can find a downloadable, more "animated" guide in Post #2.
To use with Windows machine:
1. Make sure you have secure and/or quick boot disabled in Bios.
2.Use a minimum 8Gb USB thumb drive. 3.0 works best but high quality 2.0 will suffice. Formatted Fat32. (Should be default)
3. Unpack PhoenixOS_v109_Rufus.zip
4. Run Rufus-2.9.exe
5.Select USB in the first entry.
6.Select iso towards the bottom and navigate to PhoenixOS_v1_0_9_Rooted.iso. Rufus will automatically fill in the rest of the settings. Make sure the USB drive is still selected, though. You may change the partition label if you so desire.
7. Select start.
8. Make a bite to eat.
9. When Rufus has finished reboot into your Bios settings.
10. Select USB drive from boot selection (NON-UEFI) and boot it.
11. You will be greeted by the Rufus grub menu. Select "Live CD"
12. Boot up will take some time , you will hang at "Initializing System" for a little while. (If longer than 10 minutes or so, reboot. Start at step one again, using a better quality USB this time
14. Have a look around and enjoy. You will only have about 1Gb of internal storage available, also this session will not save, so I generally don't linger too long.
7. Select start.
Before we go further it is probably time for the
This product is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to CAB approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times approximate. Simulated picture. No postage necessary if mailed in the United States. Please remain seated until the ride has come to a complete stop.Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool; process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Bg260 was here. Your canceled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Not responsible for damage to private property. Limited time offer, call now to ensure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in a well-ventilated area. Keep away from fire or flames. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free number before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Objects in mirror may be closer than they appear. Record additional transactions on back of previous stub. Unix is a registered trademark of AT&T. Do not fold, spindle or mutilate. No transfers issued until the bus comes to a complete stop. Package sold by weight, not volume. Your mileage may vary. If the flow controls supplied are not installed, this unit will not operate properly. Keep out of reach of children. When this set is used with other equipment, if the picture is not stable or the buzz sound is heard, try to change the mutual position of relevant equipment or take enough distance between them. This unit not labeled for retail sale. Phenylketonurics: contains phenylalanine. Close cover before striking. Mind the gap. No merchantability expressed or implied. Parental discretion is advised. Sold as a novelty item only. Although robust enough for general use, adventures into the esoteric periphery may reveal unexpected quirks. Not available in stores. May cause abdominal cramping and loose stools. Vitamins A, D, E, and K have been added. Not designed or intended for use in on-line control of aircraft, air traffic, aircraft navigation or aircraft communications; or in the design, construction, operation or maintenance of any nuclear facility. Container may explode if heated. May contain traces of various nuts and seeds.
This supersedes all previous notices
To Install To Hard Disk:
This is where it can vary. With every machine being slightly different. There is also the potential to "inadvertently" erase something vital. Make sure you have a "Plan B".
1. Prepare a partition to the desired size. Format to Fat32 if <32Gb. If you want more format NTFS (I would say Ext4 but Windows disk manager doesn't have that option). You can use 3rd party software such as Partition Wizard, but it is not necessary. COMMIT THIS DRIVE # TO MEMORY. If you are running Windows only, this will generally be partition 4 or 5 . (Sda4 or Sda5) You can also make a small (300Mb) partition formatted to FAT32 for Grub installation. Windows will NOT let you create a partition that size natively and you will have to use third party.
2. Boot up PhoenixOS USB.
3. Select second option "Installation".
4. Begin Guided installation. VERY IMPORTANT! Select the appropriate partition. Here is where formatting Ext4 would help as it will be the only partition formatted as such, plus if unsure you can select do not format. If you get it wrong it will format and over-write, possibly your C:\ Partition
5. Have it install Grub. Not Grub2. Or vice Versa, depending on machine. I think Grub if dual booting with windows and grub2 to if with Linux. I could be wrong. I am triple booting with Linux and Windows so Grub2 was already installed.
6. Choose partition for Grub installation.
7. Install.
8. Reboot, be sure to remove USB when safe.
9. If all went well you will be greeted with Grub menu. you will be able to choose either Windows or PhoenixOS. Enjoy. <----Dual Booting is easy.
10. If you wish to triple boot...It took me a week to figure it out finally had success with Grub2win for Windows or Grub-customizer for Linux. Alas, if you want to triple-boot, you should be able to work it out. Please share any findings as this is a work in progress.
7. Install.
I'm always available to answer questions. Unless I'm not, then I won't.
If you like it, or if I made you smile
Please hit the "like" button.
