Apps Installing Android SDK packages
chrisg220
Downloading SDK Platform Android 2.2, API 8, revision 2
Installing SDK Platform Android 2.2, API 8, revision 2
Unzip failed: C:\Program Files\android-sdk-windows\temp\PlatformPackage.new01\tools\dexdump.exe (Access is denied)
Downloading SDK Platform Android 2.1, API 7, revision 2
Installing SDK Platform Android 2.1, API 7, revision 2
Unzip failed: C:\Program Files\android-sdk-windows\temp\PlatformPackage.new01\tools\aidl.exe (Access is denied)
Downloading SDK Platform Android 2.0.1, API 6, revision 1 (Obsolete)
Installing SDK Platform Android 2.0.1, API 6, revision 1 (Obsolete)
Unzip failed: C:\Program Files\android-sdk-windows\temp\PlatformPackage.new01\tools\aapt.exe (Access is denied)
Downloading SDK Platform Android 2.0, API 5, revision 1 (Obsolete)
Installing SDK Platform Android 2.0, API 5, revision 1 (Obsolete)
Unzip failed: C:\Program Files\android-sdk-windows\temp\PlatformPackage.new01\tools\dx.bat (Access is denied)
Downloading SDK Platform Android 1.6, API 4, revision 3
Installing SDK Platform Android 1.6, API 4, revision 3
Downloading SDK Platform Android 1.5, API 3, revision 4
Installing SDK Platform Android 1.5, API 3, revision 4
Downloading SDK Platform Android 1.1, API 2, revision 1 (Obsolete)
Installing SDK Platform Android 1.1, API 2, revision 1 (Obsolete)
Downloading Samples for SDK API 8, revision 1
Installing Samples for SDK API 8, revision 1
Installed Samples for SDK API 8, revision 1
Downloading Samples for SDK API 7, revision 1
Installing Samples for SDK API 7, revision 1
Installed Samples for SDK API 7, revision 1
Skipping 'Google APIs by Google Inc., Android API 8, revision 2'; it depends on 'SDK Platform Android 2.2, API 8, revision 2' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 7, revision 1'; it depends on 'SDK Platform Android 2.1, API 7, revision 2' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 6, revision 1 (Obsolete)'; it depends on 'SDK Platform Android 2.0.1, API 6, revision 1 (Obsolete)' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 5, revision 1 (Obsolete)'; it depends on 'SDK Platform Android 2.0, API 5, revision 1 (Obsolete)' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 4, revision 2'; it depends on 'SDK Platform Android 1.6, API 4, revision 3' which was not installed.
Skipping 'Google APIs by Google Inc., Android API 3, revision 3'; it depends on 'SDK Platform Android 1.5, API 3, revision 4' which was not installed.
Downloading Usb Driver package, revision 3
Installing Usb Driver package, revision 3
Unzip failed: C:\Program Files\android-sdk-windows\temp\ExtraPackage.new01\amd64\WUDFUpdate_01007.dll (Access is denied)
Downloading Market Licensing package, revision 1
Installing Market Licensing package, revision 1
Unzip failed: C:\Program Files\android-sdk-windows\temp\ExtraPackage.new01\docs\assets-extlib\android-developer-docs.js (Access is denied)
Downloading Documentation for Android SDK, API 8, revision 1
Installing Documentation for Android SDK, API 8, revision 1
Unzip failed: C:\Program Files\android-sdk-windows\temp\DocPackage.new01\assets\search_autocomplete.js (Access is denied)
I'm young and trying to learn what some of this means. Does anyone know why my Unzips are "failing", and why my "access is denied"?
id0001- Thanks for your reply! I am an admin. I'm the only user on this computer. I should also mention, that I got that long list of "Access is Denied" messages when I was trying to install available packages within the Android SDK and AVD manager within Eclipse.
After I attempt to download packages, it just says "nothing was downloaded". Do you know what my problem might be?
You may be admin but that doesn't mean that your applications run automatically as admin.
Try the 'run as admin' button from the context menu.
I'm new with android SDK dev too :) Ur right click "run as admin" solved the access denied problem!!
Thanks
Sharath
Thanks
Sharath
Hello,
I am new into the android o/s . I have downloaded the Android kernel source code .
I am trying the isoimage building for generic_x86.
when I give the make command .
surender@surender-desktop:~/Documents/android_kernel/common$ make iso_img TARGET_PRODUCT=generic_x86
But it gives the error : I am not getting why it is giving the error.
make: *** No rule to make target `iso_img'. Stop.
Please solve this problem....
thanks
Surender Sharma
Hello,
If you type
make help
it lists all the targets, iso_img isn't listed but theres is a isoimage target.
Hello,
You don't need to build the kernel to play with the SDK.
Hope this helps
omg!!! after searching and reading for hours i stumbled accross this and it works!!!
<<<<3333
literally the last 14 hours.
i'm trying to run sdk and avd manager so i can simulate an android to play apps on my computer (since its faster than my phone) versus using my Android Samsung Acclaim.
Not gonna lie though, i'm gonna use charles proxy to hack a certain game
(is that morally wrong?)
You Rock! Thank You so much for this tip! This worked for me & It saved me countless hours of frustration!
Thank you! :)
