Root Installing Custom Recovery Without ODIN - HELP
And i also can't boot the phone itself to download an app which will do it.
Galaxy S3 is the phone.
Basically, i can't boot my phone. I can go into download mode but ODIN can't detect it. Believe me i have tried everything. Different cables, ports, drivers, computer, operating systems, ODIN versions.
TWRP is the one i am trying to install.
I have another S3 which can be detected. BUT not this one!
My HOPE is that someone knows a way to install custom recovery with a SD card somehow by going into recovery mode and installing from there.
Any responses are greatly appreciated.
I assume your device is rooted?
What recovery do you currently have, stock?
Odd that with all the methods you've tried, ODIN cannot see your device whilst in download mode. :(
Nevertheless, if you are on stock recovery, then trying to install a custom recovery via the file on the sd card I'm not thinking will work.
However, I think I'll move this thread into the root forum for your device...maybe others will have some better ideas:)
it doesn't matter really which recovery especially in your situation no offence. as long as it isnt the stock useless one. what's your recovery now?
