Installing Flash Player on KitKat
I just bought a Samsung Galaxy with 4.4.2 KitKat OS. One of the main reasons I bought this was to play games. I discovered on day one that it doesn't support Flash Player, which is needed to play the games. I'm now the proud owner of a device for which I have little use, unless someone can tell me how to get around the problem. Any help will be greatly appreciated. Thanks! :)
I'm fairly certain it is possible, or that you can install an alternate browser to do it. I haven't done it myself though. I moved this to the Applications forum where I'm sure you will get the help you need.:)
Dolphin still supports Flash iirc and there are instructions for installing Flash here: http://helpx.adobe.com/flash-player/kb/installing-flash-player-android-devices.html
I also found this, which looks to support Flash too: https://play.google.com/store/apps/details?id=mobi.browser.flashfox&hl=en
That did it! Flashfox Pro works perfectly. I upgraded to the Pro version, it was only £1.99, and it's much faster than the free version, also it doesn't have ads.
Thank you very much, El Presidente! :)
