squire1798
Is there a way to install additional fonts (primarily RTL fonts) on the MyTouch 3G Slide *without* rooting the phone? I've looked high and low, and have basically found 2 things: 1) additional fonts can't be installed, and 2) the only way that fonts can be installed - and without any guarantee - is by rooting the phone first...and even then, there might be compatibility problems.
So...am I stuck with not being able to install new fonts on Android 2.1-update 1 (current OS), or Froyo (sometime soon)?
TIA
TIA
You have done good research. Yes you must root the phone its the only way.
