A Android Question Guest Nov 18, 2015 #1 i have a box that has been wiped. i have got to the emmc card inside but how do i load/flash android onto it? thanks in advance James
glc Android Enthusiast Nov 18, 2015 #2 What box would that be? What ROMS and flashing software does the manufacturer supply? That is likely what you will need.
mikedt 你好 VIP Member Nov 18, 2015 #3 If it's a no-name Kodi box you've managed to brick, you'll most likely be buying a new one.
