Root Instant Root.apk problem when attempting to root
mrobbo
Hi all,
I am trying to route my HTC Hero (locked to Orange UK).
Following jUsT2eXy's instructions :-
1)Download it.
2)Save it to your SD Card ROOT (not in any folders)
3)Open up a file manager on your phone (Download ASTRO File Manager from the marketplace..if you don't have a file manager..)
4)Find the 'InstantRoot.apk' file.
5)Run it.
6)It will say it's been successful
Ok, so on step 4, I am opening ASTRO, clicking InstantRoot, clicking Open App Manager (other displayed option is Browse file), clicking Install (then Install again).
It then displays 'Application installed'. However, I get a notification stating 'Install Root failed / Root access was not acquired'. What am I doing wrong? Thanks.
More info if required :-
Firmware = 1.5
Baseband version = 63.18.55.06JU_6.35.08.29
Kernel version = 2.6.27-430d1aea
htc-kernel@and18-2 #959
Build number = 2.73.61.66 CL#82177 release-keys
Software version = 1.0.0.A6288
Any ideas, anyone? I got the phone on the understanding that I could easily root/install a custom ROM but I can't even root!
mrobbo, howd you get on with this?
I also tried the instantroot.apk method & i don't think its done anything. I just seem to have an app installed on my phone.
Downloaded droidwall to my phone after instantrooting it & it opens but i keep getting errors. I also tried Overclockwidget which appeared to do nothing so i don't think it worked.
I have a sim free HTC Hero (bought sim free from factory)
What did it say when you ran instantroot.apk?
The issue I had when I was getting an error with instantroot.apk was with the ROM I had at the time - 2.73.61.66 - which I downgraded to 2.73.61.5 here :-
HTC Hero - ROM Upgrade for HTC Hero (Orange)
Please note these are Orange ROMs, you say yours is sim free.
After doing this, instantroot.apk ran perfectly.
I hope some of this helps.
It had completed & it was apparently rooted. But i apps that work on rooted Heros crashed like Doidwall.
