A
Android Question
Guest
First off, I am sure this has been asked 1,000 times so I apologize, but I am still unable to find a suitable solution for me.
I have a LG Optimus F3, which I have rooted. Looking at Setting > Storage, it reports that my Total Space is 1.24 gb of which 630 mb are available. Yet, when I try to install an app, I am getting an "Insufficient storage available" error. Now the download seems to work fine. The error occurs once the download has finished and the installation process commences.
I am using Link2SD and moving apps over as they successfully install. It is also very hit-or-miss as some apps install, and some don't. For example, I purchased the Link2SD Plus upgrade and cannot get the thing to install.
Can anybody provide any suggestions as to how to fix this? Or provide an explanation as to why it is reporting insufficient storage when about half of the available internal space is free?
Thanks in advance
Thanks in advance
