Hi, in my app, when ever I press the button, it keeps crashing.
What it is supposed to do is when they press the button, an int is incremented and displayed on the screen.
MainActivity.java
activity_main.xml
<string name="text"> I Love pie</string>
MainActivity.java
Code:
package com.example.myfirstapp;
import android.os.Bundle;
import android.app.Activity;
import android.content.Intent;
import android.view.Menu;
import android.view.View;
import android.widget.EditText;
import android.widget.TextView;
public class MainActivity extends Activity {
public final static String EXTRA_MESSAGE = "com.example.myfirstapp.MESSAGE";
public int mult = 1;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_main);
@Override
public boolean onCreateOptionsMenu(Menu menu) {
getMenuInflater().inflate(R.menu.activity_main, menu);
return true;
/** Called when the user clicks on the Send button */
public void sendMessage(View view)
//Intent intent = new Intent(this, DisplayMessageActivity.class);
TextView val = (TextView) findViewById(R.id.val);
val.setText(mult);
mult+=1;
//EditText editText = (EditText) findViewById(R.id.edit_message);
//String message = editText.getText().toString();
//intent.putExtra(EXTRA_MESSAGE, message);
//startActivity(intent);
activity_main.xml
HTML:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
android:orientation="horizontal" >
<Button
android:layout_height="wrap_content"
android:onClick="sendMessage"
android:text="@string/button_send" />
<TextView
android:id="@+id/text"
android:layout_width="wrap_content"
android:layout_centerHorizontal="true"
android:layout_centerVertical="true"
android:text="@string/text"
android:textSize="30sp"
tools:context=".DisplayMessageActivity" />
<TextView
android:id="@+id/val"
android:layout_below="@+id/text"
android:layout_marginTop="37dp"
android:text=" " />
</RelativeLayout>
