Apps Intent Audio Recording
Hello All,
I am new to this forum. I am trying to invoke the default audio recorder using intents. I start intent using the startActivityForResult after the recording is complete my activity result always results 0 (which is Activity.RESULT_CANCELED) and my intent is null. My code is as below:
Code:
package com.abc.audiointent;
import android.app.Activity;
import android.content.Intent;
import android.net.Uri;
import android.os.Bundle;
import android.provider.MediaStore;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.LinearLayout;
public class AudioActivity extends Activity implements OnClickListener {
    /** Called when the activity is first created. */
    private Button sampleButton;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        LinearLayout finalContainer=new LinearLayout(this);
        sampleButton=new Button(this);
        sampleButton.setOnClickListener(this);
        sampleButton.setText("Start Audio Intent");
        finalContainer.addView(sampleButton);
        setContentView(finalContainer);
    public void onClick(View arg0) {
        // TODO Auto-generated method stub
        Intent intent = new Intent(MediaStore.Audio.Media.RECORD_SOUND_ACTION);
        startActivityForResult(intent, 1); // intent and requestCode of 1
    @Override
    protected void onActivityResult(int requestCode, int resultCode, Intent intent) {
        if (requestCode == 1) {
              // is the resultCode OK?
            if (resultCode == RESULT_OK) {
                    // lets get the uri
                  Uri audioUri = intent.getData();
                  audioUri.toString();
                    // lets play the uri or do something with it.
                 // playAudio(audioUri);
I am testing on Android 2.2.1 (device Samsung Galaxy POP). Am i missing out on something? Kindly help me with this.
Thanking you,
Regards,
S.A.Norton Stanley
