Ok, I was looking into custom roms and I downloaded one. I was trying to get into recovery but I accidentally went to the screen that says downloading... DO NOT TURN OFF TARGET. this didn't do anything and so I pulled the battery and restarted. Now the phone goes to the virgin mobile bootup and just vibrates once, then twice again and hangs.
i have tried to factory reset and clearing the cache and both don't do anything. The factory reset option goes back to the recovery list and when I select reboot it just freezes at the vm startup.
My phone is on 2.2 and is rooted and had a custom boot screen. i tried to update with update.zip and it starts and then gives me a status 7 error and aborts the update install. Is there anyway to factory reset or reinstall the stock rom? I was on the stock rom and I hadn't changed anything when I had go to the downloading screen by pressing volume down, camera, and power.
btw I never had used the sprintrom and I never changed the baseband
please help a guy out!
