internal memory erase
  • Start date Start date
A
Android Question
Guest
I am trying to load some apps from google play but keep getting "not enough internal memory available". How do I erase apps or things that will allow me to gain more memory?
Settings/Applications. Press the app you want to remove. Clear data. Clear cache. Uninstall. Go to the next one.
If you didn't install it, don't uninstall it. Uninstalling the wrong system app can turn your phone into an interesting curio.
