Help Internal memory problems
Kogama
All of the apps I download go to the internal memory of about one gigabyte not the eleven gigs only one app went to the larger storage how can I make all my apps go to the larger storage
Sounds like you want your apps stored on to SD card. You'll want to go to market and download a app to move them. Just search, apps2sd, and pick which one you like. Then after getting set up, every time you download something that has the option to move to the SD card it will let you know (not all apps can)
It will also let you move the ones you already downloaded as well.
