I bought a pay as you go Android phone from Wal-Mart for about $130 and the be completely honest I want to throw the thing into the wall.
Not sure if it's the phone itself or the just the operating system. My biggest issue is the fact that when the phone attempts to download new apps or update existing apps it says I have no storage. The phone itself has internal storage of about 200mb and comes with a 2gb Micro SD card.
Here lies the problem. Every time I download a application it downloads to the internal memory, there has to be a way to change that, right? Because that is ridiculous.
I managed to move the majority of my applications to my SD card however theres a lot of applications that simply can't be moved to a SD card and that's my main reason for posting this thread. Why can't I move some applications to a SD card? Some will let me and some won't and those that won't let me I usually uninstall unless they're of a tiny size due to the internal storage size.
Also if anyone could tell me how to remove the crapware Google put on the OS (Books, Google +, etc) i would appreciate that also. It seems you can't uninstall any of those.
