Root [International] backup data help
Titanium is by far the best...game data, perhaps "my backup pro". This will also backup contacts although it makes more sense to just use Google contacts.
Photos can auto upload to dropbox.
You could also use folder sync to backup sd data. Have a look for a thread I created with my backup routines listed for some ideas.
http://androidforums.com/showthread.php?p=5372021
Titanium would still be the best for game data though. There's no single solution to your problem here either
Titanium is the best IMO. Anyway you might try ROM Toolbox Pro or Carbon Backup. Both should be able to do the same job of TBU.
I had bad experience with My Backup Pro so il never use it again. Think Titanium is the tried and tested best bet. The dev' of Rom Toolbox is actively tryin to compete with Titanium but i havent tried it :thumbup:
