Any time the icon is grey, it means it doesn't have a secure connection to Google's servers. You probably still have at least some kind of data connection, it's just having trouble establishing its secure connection to Google.
The H means you're using the high-speed data connection (faster than 3G). The arrows on the connection are just indicating that it's either sending (arrow pointing up) or receiving (arrow pointing down) data. If you watch the arrows closely, you'll see that they'll turn on or off depending on what your device is doing... and sometimes they won't be there at all.
Not exactly. When the Wifi icon turns blue it means Google is syncing. When they are gray, it's not.
But it's still blue, when I have sync turned off, and the signal bar being blue?
Well, I think his comment was a distinction without a difference
Petrah, correct me if I'm wrong here, but it actually doesn't mean anything is actively syncing. All it means is that it has the connection to Google's cloud servers, and thus is capable of syncing. Which is what I said, only I left out the specific reason why it creates the secure connection to the servers.
