[International / GSM] 4.2 MMS Help (T-Mobile)
Ever since I installed the update I can no longer send MMS's. Here's a screenshot of my settings (which I haven't messed with). Any advice?
I would try another sms app. If that fixes it then you would know the problem potentially lies within that app.
You could try clearing the app's cache in the apps system section.
I had a similar problem about two weeks ago with handcent but it ended up being a bug in the app that the developer fixed.
