[International / GSM] Cm9...
BSP
Member
Hi everyone!
I just wanted to know if it is possible to get a search softkey button add-on in CM9 on my GSM GNex. Is there a download link for a .zip which I can flash, or is it built into settings (where specifically?) Thanks
Thanks for replying. I had the search function on a different deodoxed rom, but I decided to switch to CM9. Because of that, I don't want to use a custom ROM. I just want to know if there is an ability to add the search key while using CM9. I tried a couple softkey mods, but it always ended with 'SystemUI has failed' and me having to restore my phone.
