[International / GSM] persistant searchbar on liquidsmooth
patch321
anyway to bring this back using the stock launcher? no, i don't want to try apex. :rolleyes: thanks though. any help would be greatly appreciated!!!
Isn't it an option in the apps?
I use Nova Launcher so I haven't even looked at stock since rooting. Let me know if you dont see it as an option and I'll see what I can find.
It's ok. The Google Search Bar is actually an 'app'. It has a widget. So you need to go into your Widgets, long press it to grab it and place it wherever you want on your screen.
i've done that but it doesnt look the same. and it doesn't act in the same manner as well. i believe the widget is part of the google search app where the persistant seach bar belongs to the stock launcher.
