I just can't get the sdk installed. I tried on 2 different computers. One was w/ Vista, and oneis w/ Win XP and am following the instructions from here:
Howto: Install the Android SDK - CyanogenMod Wiki
I have a problem w/ this step. I unzip the file to the root of my C drive and then :
4. When you launch the SDK Manager for the first time it will ask for which packages to install. The only package we are concerned with at this time is "Android SDK Tools, revision 15", "Android SDK Platform-tools, revision 9" & "Google USB Driver package, revision 4". You can reject all the others if you are not interested in them.
It just opens a black DOS window and then closes. I have no chance to select anything. Is it installed? Can I move on?
