Root [International] help please
When you first flashed it should of given you the option to make a backup, flash that or reflash the illusion theme and select stock for whatever you changed the first time.
It should be a zip in a folder called UniversalFlasher on your phone's internal sd. Just flash with recovery the same as you did before.
