Root [International] HK Theme Manager module (Xposed)
funkylogik
share the love peeps ;)
Anyone tried it on a non-CM aosp custom rom?
Its working nicely on my stock nexus7.
It lets you use CM themes on a stock rom. Pretty cool :beer:
No tried anything much with Xposed. Installed the framework yesterday...had a small play..added CPU temps to notification bar, applied transparent theme to BBC weather widget.....really could do with some pointers as to what I can do with Xposed?
Just go through the download section and click on individual modules. Then read the description. For example, I don't like any keyboard without Alt symbols so I downloaded and installed the module to enable it on Samsung's keyboard; now long-press a letter and the corresponding symbol appears. Another irk is the long delay when long-pressing a key for the alt symbol, well there is a module to reduce that delay significantly and makes the alt symbol appears almost instantaneous.
Another pet hate of mine is the 'Clear defaults' instructions after choosing a default action, which pops up very frequently. Downloaded a module that stops that nonsense.
Also, the de facto standard for Xposed modules for Samsung ROMs is Wanam's module, which covers pretty much everything you would want to customise appearance and functions of stock based ROMs that will get you to a look and feel of custom ROMs, such as centre clock position, circle battery, transparency of the status bar, no SMS in call log and much more.
Theres a good g+ community called Xposed Framework with a lot of good tips and pointers.
For aosp roms, gravitybox and xblast tools are good and packed with features.
HK Theme Manager seems to keep putting my tab into airplane mode so id gona deactivate that until its less buggy :-)
funky do you know of any alternative sources for modules that are not in the official repository for download? I've looked through the official repository and wondered whether there are other modules available.
Ha, ha second that Heat, also got the module that removed the bloody annoying VPN warning. Have to admit it's these wee modules I use more than the modification stuff, never seem to have the time to play about with those.
Youtube AdAway is another good wee one.
These are what i have installed (not all of them activated) uploadfromtaptalk1391015056861.jpg
EDIT actually i have more than that. Those are just the ones that can be opened
P.s, i used Xposed Preferance Injector to put the modules into my settings menu
Tbh im not sure mate. I havent seen an ad since using it but i maybe dont watch the type of vids that would have ads anyway lol.
Can you link a vid i could test?
Im loving Xuimod for scroll effects and animations.
Ive re-added the "bounce" at end of scroll list that apple sued over. Just lil touches that make a difference :)
Aparently there isnt mate although people agree it would be a great idea.
Some dude keeps trying to suggest Preference Injector even though i clearly stated "LIKE Preference Injector but for any app" :)
Hopefully a dev will pick up on it.
What a guy suggested that would be cool is if we could add a named folder of apps to the settings menu
